Mk2 Engine Question
Car-Nut
Mk2 Engine Question
Postby Car-Nut » Thu Sep 06, 2012 8:56 pm
I was with someone today who showed me
an engine out of a 2.4 mk2.
On the block however it had Jaguar 3.5 any clues :?:
Clive
(Car- Nut)
MK7, 8 & 9 Forum Co-ordinator
MK10 420G Forum Co-ordinator
:arrow: 1970 - 420G - WiP
:arrow: 1962 - E-Type FHC
:arrow: 1997 - X330 4.0
ecosselynx
Re: Mk2 Engine Question
Postby ecosselynx » Fri Sep 07, 2012 5:24 pm
Hi Clive
The 3.4/3.8 engine blocks have the same. I think it was probably just Jaguar saving money. Copied the same pattern and just shortened it for casting the 2.4 blocks.
Any more thoughts!
bye-o
John H.
Martec
Postby Martec » Sat Sep 08, 2012 7:50 pm
Is it a 3.4/3.8 engine fitted into a 2.4 car.
The engine code will give the game away
BG on 2.4 engines
KG on 3.4 engines and
LA on 3.8's
Car-Nut
Postby Car-Nut » Mon Sep 10, 2012 12:35 pm
Brian, they believe its a 2.4
Clive
(Car- Nut)
ecosselynx
Postby ecosselynx » Mon Sep 10, 2012 1:20 pm
Hi Clive
You'll know by the block height, 2.4 is about 2.!!!! shorter than a 3.4/8. As Brian said check the number. Another quick observation would be the carb mounting on the inlet manifold.
bye-o
John H.
Car-Nut
Postby Car-Nut » Mon Sep 10, 2012 1:32 pm
Thanks gents..
I will report back soon :)
Clive
(Car- Nut)
