Gas pick up tank getting hot
grantedwish
Postby grantedwish » Wed Jun 27, 2012 2:20 am
My gas return is heating the small pick up tank and causing the pump to get hot and bog and stall the engine. The temp gauge reads between cool and normal. A/C is not working at the moment but will get it working. Car should run without A/C even on hotter days. I put a spare pump on when this happened and the car ran great until the other pump got hot.
grantedwish
Re: Gas pick up tank getting hot
Postby grantedwish » Wed Jun 27, 2012 2:22 am
Sorry Car is XJSC 5.3 litre v12....
grantedwish
Postby grantedwish » Fri Jul 20, 2012 7:14 pm
A new pump has worked and fixing the A/C has improved things still more.
