Parking sensors.
tezles42
Parking sensors.
Postby tezles42 » Sun May 13, 2012 4:53 pm
In the not too distant past i had an intermitant bleeping as soon as i put the car in reverse. This was worse in the winter or after i had the car washed. In the summer the parking sensors were ok so this led me to the conclusion a sensor was defective. The boot is bone dry as is the parking module. On a recent visit to the garage they said that a fault code registered a rear o/s corner parking sensor fault. Since then however when reverse is selected i now get a constant 3 second bleep then nothing. I have tried listening to the rear sensors to see if there is a clicking when passing but nothing. Is this an indication the module has given up the ghost. I have cleaned the connections with no gain. It does not matter how close i get to an object there is no indication via an audible sound.
Montana5
Re: Parking sensors.
Postby Montana5 » Sun May 13, 2012 8:58 pm
Hi, before you get to the bumper off stage, have a read at this, just incase there is something there that might save you a bit of time...
http://www.jec.org.uk/forums/viewtopic.php?f=283&t=5216
Doug.
S Type Forum Moderator
