Have my eye on some discs that are for a 1998 XJR , will they fit my 2000 W XJ8
The description on sizes is as follows.......
Fronts appear to be 305mm across x 28 mm thick
Rears are about 305 mm across x 18- 20 mm thick
As stated..they are whatever the standard disk setup is for a 1998 car.
Will standard XJR discs fits a xj8??
jaguar4321
Re: Will standard XJR discs fits a xj8??
from memory ,
they will fit BUT
you will need new callipers , as i think the R had larger brakes as standard over the standard XK and XJ
hope this helps
they will fit BUT
hope this helps
jaguar4321
Thats a big But!
This link shows standard XJ8 disc spec sizes.
http://www.apcarparts.com/mintex-front- ... 1640-p.asp
jaguar4321
Hi, That looks to say they are the same size?
Here is what is listed for the XJR disc sizes.
http://www.justpartsbiz.co.uk/acatalog/ ... -2002.html
Compare with my previous link and ensure they are one and the same part number or equivalent.. That being so, you should be ok.
I believe the later 4.2 models had larger discs and as BB says, Brembo or jaguar enlarged callipers.
Perhaps Rob could also advise when he gets back from Stoneleigh spares day.
jaguar4321
Done some checks, the dimensions are the same as my car, just won the 4 x discs (EBC) drilled and grooved for £19.99!
jaguar4321
£ 19.99 ebay wins cleaned up and ready for fitting!
- Attachments
- IMG00419-20120409-1719.jpg (32.47KiB)Viewed 5912 times
jaguar4321
so you have Brembo callipers anyway ?
that means you have a big brake kit fitted over standard
bargain
bargain
jaguar4321
All i need now is the 4.0 engine and the Supercharger now!
Having said that i was surprised how nimble the 3.2 is, i hear you can get up to 30 miles to the gallon on a run?
my normally aspirated 4ltr gets 34mpg .
the 4ltr is known to be more efficient than the 3.2 , strange but true
jaguar4321
Wow!
Thats great for a V8!
I had a Mercedes GL450 CDI that was a V8 CDI, i never got that over 33mpg!
