Hi new member here looking for help please
wsdmcs01
Postby wsdmcs01 » Mon Mar 26, 2012 8:25 am
I am looking for a solenoid and rubber gasket for the the fuel filler on my 1987 3.6 xj40 can anyone suggest a supplier?
Thanks Martyn
nashio966
Re: Hi new member here looking for help please
Postby nashio966 » Mon Mar 26, 2012 10:24 am
Welcome :)
Can't help personally but Robv12 will almost certainly know :)
robv12
Postby robv12 » Mon Mar 26, 2012 10:43 am
you are going to struggle here, best work out what the issue is first, my guess is that the fuel filler flap will not pop up when pressed down to open it??, later cars had this feature designed out as it was so unreliable
options, check the in line fuse in the boot, left hand side behind the carpet, it may be blown, next remove the filler unit, a fiddly task as the tank has to be moved, dismantle clean and check the solenoid, often water and dirt ingress stope them working
If all this fails, look for a seconhand one that you can test on a car that is being broken, most have failed by now OR fit a later style flap, if you go this route the flap will not lock and you will also need to fit a small spacer on the underside of it to get it to sit flush with the rear deck, I have seen small magnets used for this purpose
I have later style filer flaps here, various colours and one early style complete filler unit not checked, so assume not working, pm me if you need more details
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
wsdmcs01
Postby wsdmcs01 » Mon Mar 26, 2012 2:40 pm
Thanks for the messages fellas, it is the rubber gasket that is causing me the biggest problem?
robv12
Postby robv12 » Thu Mar 29, 2012 5:13 pm
ok will have a look in my stash for a good one
wsdmcs01
Postby wsdmcs01 » Sat Apr 07, 2012 12:14 pm
Hi i have now got a new gasket from Jaguar and a replacement solenoid from all4jags, many thanks for all your help.
Martyn
robv12
Postby robv12 » Sat Apr 07, 2012 10:08 pm
glad you got it sorted
