Timing chain tensioners
richardtoulouse
Postby richardtoulouse » Thu Feb 16, 2012 4:44 pm
I am in a similare situation with my S Type 4.0 2001. I'v got very low mileage (50 000kms) and I just had a call to neville Anderson www.jaguarspares-northeast.co.uk, he recommande to replace all the item and with the complete kit....
We have a post on this subject with Mike on S-type forum and said "There is considerably more work needed to remove primary guide rails and the primary tensioner. The crank pully has to be removed and many of the ancillary components to gain access to bolts etc. I also understand that (can someone please confirm?) one of the bolts holding the timing cover in place hits the subframe when removed. I have heard the engine the needs to be lifted to clear that obstruction."
Do you know if a drawing showing all the parts exist?
Can somebody help?
Richard
french guy with some English cars in France
XJS 3.6 & S type V8 4.0
Re: Timing chain tensioners
Postby J44EAG » Thu Feb 16, 2012 5:22 pm
richardtoulouse
Postby richardtoulouse » Thu Feb 16, 2012 6:21 pm
Mike,
Neville advice is to replace the complete kit. The mileage is a contributor but not only, the age it is another....
Based on data provided in the document provided, it sound that I need to remove the timming cover plate to replace the kit......
I assume that the chain would be good, not all the others tensionners.
I need to get more lesson learnt from memnbers to take a decision!
Ratio between the investment (time and euro) and the risk mitigation. Difficult subject!
Richard
Richard
Postby J44EAG » Thu Feb 16, 2012 6:25 pm
What mileage have you on the car, Richard?
M
richardtoulouse
Postby richardtoulouse » Fri Feb 17, 2012 11:44 am
in EU units: 50 000kms
in UK units: 31 000 miles
I take the opportunity to speak about the standar used by Jaguar. the nuts of my XJS are not in metric when I feel that all the S-type use metric.
It is correct, if not, what is the span of the true?
Thanks,
Richard
Postby J44EAG » Fri Feb 17, 2012 12:10 pm
Hello Richard,
Your car is very low mileage.
The primary guides are unlikely to be cracked at 31,000 miles. That tends to happen between 90,000 - 100,000 miles. Even then, the guides will usually be ok for service up to around 150,000 miles even if there are cracks in them. Failure is not common. Some engines have been known to cover 200,000 without problems.
Primary timing chains are usually good for about 150,000 after which they can become noisy. At that point an owner will normally have the chains and guides changed if he wishes to restore that part of the timing equipment to as new condition. I cannot see a reason for you to change primary chains and guides at 31,000 miles. There is a great amount of life still left in that part of your V8 and it will not be necessary for you to spend money on the primary components at such low mileage. Keep the money in your pocket and buy me a beer at Weston Park!
The secondary tensioners, if made from plastic should be changed as soon as possible. The first early signs of cracking may be visible. My secondary tensioners had large cracks in them when I changed them at 44,000 miles. I also found that the secondary chains were ok and therefore I did not change them on my car. The car has now done 77,000 miles and there are no loud chain noises or other problems in that area of the engine.
I would suggest you change only the secondary tensioners which are available from Neville or other parts outlets for around £45 for each unit. Shipping will be a small additional cost.
The S-type has metric S.I threads for nuts and bolts across the whole car. You will not find any Imperial sized fixings.
richardtoulouse
Postby richardtoulouse » Fri Feb 17, 2012 8:17 pm
Well,
I removed the part that allow me to see the tensioner and the chain (I don't remind his english name. In French: cache culbuter, probably rocker something in english).
The probleme is that I thaught that the screw will be atached to the part and ..... 5 diseapeard somewhere...
I found 4, one is missing.
The risk is that it follow the chain....... I hope no.
However, my tensioners are very good! Anyway, I will change them.
Next slote to work on it: Sunday !
Sad night!
Richard
Postby J44EAG » Fri Feb 17, 2012 8:43 pm
Mais non, mon Capitaine!
L`Affaire du fixament disparu et l`explosion magnifique! Ill est un disasteur fantasique!!
I think the bolt might have fallen into the sump. I hope it does not make contact with the chains.
mike
richardtoulouse
Postby richardtoulouse » Mon Feb 20, 2012 10:41 am
So,
I searched during 3 hours friday night my bolt without success..
Saturday, I was unavailable ( we had a lunch with a famous cooker, french marvelous food and we had seven kind of wine, but that it is another story, we live in the south west of french, we know why....)
Sunday, wy wyfe went to help me to found the bolt. Afer two hours, we found it !
It was below the fuse box, behind the light !!!!
Marvelous, the engine didn't eat it!
Now, I have one question:
I worked to remove the left one, however, I do not understand how I can remove the tube that allow to measure the oil level.
Do you understand wy issue? Can you help me?
Thanks a lot again for your support, I start to like working on this car. When I will work on my older cars, it will be so esay.
Richard
Richard
Postby J44EAG » Mon Feb 20, 2012 11:26 am
Hello Richard.
I am very pleased to hear you recovered the bolt and that it did not fall into the engine.
I think I understand your question about the dip stick tube. I know that it covers one of the 7mm bolts and that it is impossible to remove that bolt with the tube in that position.
There is a simple way to overcome the problem. If you remove the oil level dip stick, and then insert a strong round piece of metal of approximately 8mm diameter into the tube, you will be able to bend the tube away from the engine and will then be able to place a small 7mm socket and wrench on the bolt to remove it. The problem is then solved.
It is not necessary to bend the tube back to the original position after you have completed your work. That will make access to that bolt easier in the future.
The image below shows what I did to my V8 dip stick tube because of the same problem you have experienced.
Adjusted dipstick position..jpg (72.2KiB)Viewed 4379 times
richardtoulouse
Postby richardtoulouse » Mon Feb 20, 2012 1:58 pm
Thanks,
it is very confortable to work in the JEC contexct......
You know what? August 26th has been identified as to be an option.....
We will see.
Richard
Richard
richardtoulouse
Postby richardtoulouse » Mon Feb 20, 2012 3:23 pm
Mike,
I went true the BB and didn't find the procedure to remove the tensioners.
I understood that I need a tool to avoid the axe moving, have you got some pitcures?
How do I remove the tensioners? They are under tension......
Richard
Postby J44EAG » Mon Feb 20, 2012 4:14 pm
Hello Richard,
You will need to contact Annie Jenkins at the JEC Tools and Spares Department and rent a camshaft locking tool. It locks down the camshafts so that they cannot move when you change the tensioners. Annie will be able to give you prices for renting the tool. Details in the front of the magazine in the Club information section.
The tensioners are two bolt fixed for each unit. The bolts for the new aluminium units are supplied with the kit. I remember that they are a little longer than the original bolts.
I think there is a stage by stage post on the X308 BB with photographs. Perhaps I am wrong but I think our friend Brake Buster wrote the post two or three years previously. I am short of time today but will try to find the post for you this evening.
I am glad you might come to the JEC Portsmouth event on 26th August. It is to be held on the hill which overlooks Portsmouth Harbour and the ferry terminal where you will arrive. Our event is only 4 miles from the terminal. It would be good to see you.
Postby J44EAG » Thu Feb 23, 2012 5:57 pm
Hello Richard,
Go to the X308BB. Go to "engine" then go to the post "i changed my timing chain tensioners yesterday!!!!!". Author is Brake Buster.
This is the best post that we have regarding changing of tensioners. There is photographs and text.
Top job Brake Buster. Beer is on me when we eventually meet up.
richardtoulouse
Postby richardtoulouse » Fri Feb 24, 2012 10:58 am
i just spend few minutes on this post, I now understand how the tools objectives are.
Because it would not be easy for me to rent the tools from the club (delay to be delivered and returned to France and my current schedule workload and availability....) I plan to make them!
I will take the measures on the engine and draw the need.
The most difficult would be to do the tool to block the wheel, the tool to block the axes is very easy to made.
As soon as the job would be done, I will post the draw and comments on the BB!
Have a good week end,
Richard
Richard
