Heated front windscreen
Moderators:robv12, DavidEm
tony2Jags
Postby tony2Jags » Sat Feb 11, 2012 11:27 am
Hi Guys.
I have a Jag XJ8 (X308) 3.2L auto and recently the heated front windscreen has stopped working. I changed the fuses and both relay switches. Checked circuits, all seam fine, but there must be a circuit break somewhere.
Could anyone point me in right direction to get it working again.
I'm trying to find the connectors....are they located in the windscreen pillars or in the engine bay?
Any pointers would be greatly appreciated.
Tony :roll:
Re: Heated front windscreen
Postby Brakebuster » Sun Feb 12, 2012 11:04 am
the plug in connections are located at the bottom corners of the screen either side of the car from under the windscreen scuttle , the wiring should run towards the middle of the bulkhead to another connector ,
if both sides have stopped working , then i would be looking at control rather than equipment ,
check the wiring connector on the back of the AC control panel , or even the switch its self ,
after that , its anyones guess
good luck
tony2Jags
Postby tony2Jags » Sun Feb 12, 2012 6:45 pm
good luck
Hi BB
Many thanks for info. I'll your advise & let you know.
Tony :D
