water Leak
Moderators:robv12, DavidEm
hector
water Leak
Postby hector » Thu Dec 29, 2011 10:25 am
My X308 Yr 2000 has a water leak when put through a car wash, there seems to be water in the top gulley then clears once car is on the move. The water comes in to the car via the brake pedal. this only happens when the car is in the wash under presure. Is there a drain pipe that could be blocked, any ideas?
andypryce
Re: water Leak
Postby andypryce » Fri Dec 30, 2011 11:52 pm
Almost bound to be either a blocked drain plug from beneath windscreen somewhere, check by pouring water onto screen and then using a straightened wire coat hanger to poke down the drain holes, or a grommet surrounding a cable running from the bulkhead to the footwell. Had the latter problem on mine a few years ago, turned out that when the speedo cable was replaced the bulkhead grommet had not been fitted properly, so water ran along the cable into the footwell. Bit of systematic detective work should find the problem. Good luck!
andyp
XF Sportbrake 2020 / XK8 1998
robv12
Re: water Leak
Postby robv12 » Sat Dec 31, 2011 4:42 pm
does the car have a sunroof??, if so could well be a blocked sunrof drain
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
hector
Re: water Leak
Postby hector » Sat Dec 31, 2011 4:43 pm
Thank's Andy, looking at the front I guess I will have to remove the plastic cover.
andypryce
Re: water Leak
Postby andypryce » Sat Dec 31, 2011 6:46 pm
Yes, I think so, if you pour water over the screen you should see the water draining, from memory I think it drains to wheel arch areas both sides?
hector
Re: water Leak
Postby hector » Sun Jan 01, 2012 10:03 am
The car is a standard Executive without sunroof.
robv12
Re: water Leak
Postby robv12 » Sun Jan 01, 2012 5:07 pm
ok so we can count out blocked sunroof drains then!!
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
