Interior rugs/mats part numbers
maxbozon
Postby maxbozon » Sun Nov 20, 2011 1:51 am
Hi!
I am want to buy some interior mat/rugs for my X300, but I am a bit confused with part numbers of these rugs.
On jaguarclassicparts.com they start with 'GNB' (and ones I need are not in stock...), but most of other suppliers put 'JLM' part numbers but without description of what colour is it, which side should it fit etc., usually it just says "Tailored Mat" or something like that.
Does anyone possibly have a list of these 'JLM' part numbers with description?
I need a full set of 'coffee' coloured mats with Jaguar logo for a late x300 (1997) Executive. These can be tailored or lambswool mats (I'd probably prefer lambswool, though).
Cheers,
Max
robv12
Re: Interior rugs/mats part numbers
Postby robv12 » Sat Dec 17, 2011 5:41 pm
Max, looking at the availability of these you could be out of luck, all i can find are the following for SWB RHD cars
tailored carpets
REAR RH GNA9483AASDC @ £10.00
REAR LH GNA9482AASDC @ £19.32
FRONT LH GNA9493CASDC @ £22.51
FRONT RH n/a with Jaguar logo
FRONT RH DAIMLER GNA9426BASDC @ £45.00
lambswool rugs
REAR RH GXF9585AASCD @ £35.00
REAR LH GXF9584AASCD @ £35.00
FRONT RH JAGUAR GNA9580ABSCD @ £45.00
FRONT LH GNA9581CBSDC n/a
so as you can see one item missing from each set
if it were me I would go for a part set of three lambswool and get the drivers side front which is the one thst takes the most wear and keep a look out for an odd one on ebay or similar for the passenger front
On JH parts I can find no reference to the JLM part nos
hope this helps a liitle
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
maxbozon
Postby maxbozon » Sat Dec 17, 2011 5:52 pm
Thank you very much, Rob!
Well, that sheds some light on to the question! Where did you get these prices and availablity from?
X300 Executive Auto, 3.2L, 1997
robv12
Postby robv12 » Sat Dec 17, 2011 6:02 pm
Jaguar Heritage and then onto the Classic parts website
http://www.jaguarheritage.org/ClassicJaguarParts.aspx
a tip though, if a 300 part number is the same as a 308 part number it will show on classic parts as "contact us" this is because all 308 parts are still only available from Jaguar direct
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
maxbozon
Postby maxbozon » Sun Dec 18, 2011 8:14 am
Aaa :) I see thanks a lot for the hint with X308.
Jaguar Classic Parts is where I started my search initially. Now it seems that probably rear rugs are the same for X300 and X308 then... (those you quoted are for LWB). But I have seen some from Martin Robey and David Manners, those start with JLM number.
I see that probably the best way is to contact them directly and ask what they have to offer :)
Thanks again!
