Hello everybody,
I am thinking about updating my 2008 Satnav mapping software . Does anyone know of a decent source / supply of the necessary discs ?.
I would be most grateful of any info. best regards, Chris Bartram.
Satnav update.
Re: Satnav update.
Hi, I am pretty sure that only place you can get one is from navteq:
http://www.navigation.com/is-bin/INTERS ... ault-Start#
andyp
andyp
Re: Satnav update.
Also found this on ebay:
http://www.ebay.co.uk/itm/Jaguar-XJ-S-T ... 500wt_1202
A bit cheaper, though beware as I bought one from there once and the disc was blank...
Re: Satnav update.
I am also looking to update my sat nav from 2007 - 2008 to the latest available. Did anyone resolve where to obtain the discs?
Re: Satnav update.
Bought one of these for my XJ, works a treat:
ebay item: 281334174787
Copies i guess as original disc update from navteq is £160, which is a total rip off as you can now get free sat nav on your phone with google maps app.....
andy
andy
XF Sportbrake 2020 / XK8 1998
Re: Satnav update.
Thanks for quick reply, I will get a copy and let you know how I get on
Thanks again
Thanks again
Re: Satnav update.
PS: Note this is 2009-2010 disc , i think if you want the very latest one you probably need to go to navteq, but it is quite adequate.
andy
andy
Re: Satnav update.
I took the plunge and bought the ebay disc No (261476386594). It cost £20.00 and I followed the instructions enclosed which worked fine. No problems encountered and it is now showing 2011-12 as the version on the car. I have used it for short journeys and again it works fine.
Hope this helps
Hope this helps
