Security Module XK8 2002
Does anybody know where I can get a security module checked and refurbished?
Re: Security Module XK8 2002
Hi Maximus ,
Don't know where you are in the country but you would need the module interrogated by a Jaguar WDS or IDS machine to check it's integrity ( possibly Autologic?) , normally only found at main agents but specialists such as DesignXKR in Andover have a WDS and will be very helpful , ask for Kevin or Soraya and tell them Nik recommended you ,
Hope this helps ,
Nik
Hope this helps ,
Nik
If you are certain that the module has collapsed, here might be one alternative solution. Ouch!
Some re programming would appear to be required after installation.
http://www.ebay.co.uk/itm/Jaguar-XK8-Co ... 3f06b7def2
That however is only one seller. Might be worth doing some hunting around via sources such as Eurojag to see what others are selling used servicable modules for. I can understand you wanting to have your module overhauled if economic.
As Nik says, best to have the car interrogated first to assure yourself that you do have a problem with the installed module.
Mike K.
Mike K.
Thanks for the help. I managed to get my hands ona second hand unit and everything is now working, but I would like to get the old unit fixed as a spare. I will give Design xkr a call
Hi Maximus
Did the security module just swap over without any reprogramming
I thought they needed pairing to the ECU
All the best ,
Nik
All the best ,
Nik
I got the identical module and part number and all had to do was programme the fobs. It is all working now. Could I just be lucky?
