Fault solved by cleaning main bus bar rail in engine bay and removing 4 pin plug in ignition switch cable. Volt meter now reads 14v for the first time since i have had the car. The volt meter no longer drops with brake pressed as seen in video link
http://www.youtube.com/user/540satnav#p/u/5/c-LH4MR_dEA
Volt meter on dash reads below 13v & Drops with brake press
540itouring
Re: Volt meter on dash reads below 13v & Drops with brake pr
What is the bus bar rail you are referring to. Mine is an AJ16 and I don't see it (unless I'm looking in the wrong place of course). Did clean the 4 pin connector and that alone made a bit of a difference. Thanks for the advice.
Nick
Nick
