XJ12 Series 1 - Fuel
richardpierce
Postby richardpierce » Thu Aug 25, 2011 8:11 pm
Can anyone tell me if it is ok to run my XJ12 Series 1 on unleaded fuel once it is on the road, or do I have to put 4 star in.
Any assistance much apprciated
555ttg
Re: XJ12 Series 1 - Fuel
Postby 555ttg » Thu Aug 25, 2011 9:23 pm
Richard,
I run my series 1 XJ12 on unleaded regular gas,(petrol). It does no harm to the engine, because Jaguars all have hardened valve seats, which is what you have to do if running a Triumph or MG on unleaded because BL didn't think the 'lower priced' cars were worth the extra effort! (At least that's what I've been told).
Phil
1973 Series 1 XJ12 SWB
1977 Series 2 XJ6C
1987 XJ-S 5.3 litre auto Cabriolet
1989 LISTER modified XJ40
1993 XJS 4.0 litre Manual facelift
stuarthardy
Postby stuarthardy » Fri Aug 26, 2011 9:08 am
I think unleaded is fine because, as Phil said, hardened valve seats are fitted as standard although its because the cylinder heads are aluminium and therefore would wear out in no time if steel seat inserts weren't fitted.
It is my understanding that North America (or at least parts of) hasn't had leaded fuel since the 1970's and Jaguars have run there all this time without problems (well, valve seat problems anyway).
Hope this is some help.
Stuart
XjRestorations
Postby XjRestorations » Fri Aug 26, 2011 11:25 am
All the info so far is spot on :-)
ALL V12 engines will run unleaded with no problems at all!
All the best,
Keith
richardpierce
Postby richardpierce » Fri Aug 26, 2011 11:40 am
Thanks guys, unleaded it is then
