Tensioners on replacement engine?
KevRen
Postby KevRen » Sun Jul 10, 2011 4:09 pm
Hello all
I'm wondering again about chains and tensioners and, using the websites new archive was able to find illustrated step by step instructions for replacing the latter. Looks fairly straightforward as long as you are methodical and do as you're told! However, my engine was replaced in June 2003 and I was hoping it might have the last generation tensioners (and waterpump?) fitted. I have a service record from HA Fox of Nottingham which includes the engine number on the invoices for the work done. However the engine number on invoices pre- and post-engine change are the same. Is it possible to find the engine number anywhere else? I can't find the green replacement engine tag, although I'm not exactly sure where on the engine to look.
Kevin
Nik
Re: Tensioners on replacement engine?
Postby Nik » Sun Jul 10, 2011 10:07 pm
The easiest way of checking which generation of tensioners are fitted would be to take off the cam covers and take a look , that way you can be 100% sure they are the all metal jobs :wink: ,
Hope this helps ,
Nik
robv12
Postby robv12 » Fri Jul 15, 2011 5:07 pm
i have to agree, whip a cover off and check, that way you will 100% sure, allow an hour for one side, and careful not to drop the one cam cover bolt that is not captive!!
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
KevRen
Postby KevRen » Fri Jul 15, 2011 9:10 pm
Thanks very much for the advice. :D Will I need to replace gaskets/sealant if I'm just whipping the cover off briefly? If so, where is the best place to get these from? Also, I've now been frightened by the non-captive bolt issue! What is that all about?!
Kevin
robv12
Postby robv12 » Fri Jul 15, 2011 9:44 pm
it's some time since I did one of these, but the bolts that hold the cam cover on are 10mm from memory, all are captive in the cam cover bar one on the cars I have done, again from memory it is one of the rear two, the lower one I think, the first car I did as i pulled the cam cover off this bolt made a bid for freedom, lucliky i caught it in time, not having done a huge number of these, someone who does them all the time or has done one recently will be able to confirm if I am correct or not
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
aaj
Postby aaj » Sat Jul 16, 2011 10:15 am
I had to replace cam cover gaskets 2 years ago
As Rob says there is one of the rear bolts not captive - I missed it on the LHS Cover & never found it - I only know it never went into the engine!
I also had a happy find - my 4.0 engine had the 4.2 Chains & Tensioners!
On the LHS you will need to get your Dremel out & cut a slot in the Dip Stick tube bracket to release it (do not pull tube off engine as I believe it's a pig to get back in place) & remember to clean off all the swarf before removing cover.
The latest water pump is 2 parts and has an extra 2 bolts (making 7) holding the assembly together, the older pump is a single casting.
Each variation of the Engine (not just 4.0 & 4.2 but the earlier version of the 4.0) has different gaskets & don't forget to replace the VT actuator seals if they are located through the cam cover.
Good Luck
Allan Jones
XK8 Registrar
KevRen
Postby KevRen » Tue Jul 19, 2011 7:33 pm
Many thanks for the advice. I think I will take off the covers for inspection this winter. Then at least if the job needs doing I won't lose valuable driving time whilst doing te job. :)
Kevin
