tacho faulty after coil change
Moderators:iRS, Art1012
frogeyeman
Postby frogeyeman » Thu Jul 07, 2011 11:15 pm
Hi,first time on.Changed the coil on my series 2 e type for a red Accu one.On first drive had misfire and tacho not going above 2,000 revs.Put old coil back on and engine now running fine but tacho still same problem.Any ideas why the tacho went faulty.Running Lumenition ignition system.Anybody got a spare tacho?
piman
Re: tacho faulty after coil change
Postby piman » Fri Jul 08, 2011 6:54 am
Hello Frogeyeman,
isn't your tachometer the usual Jaguar one driven by a generator of the rear of the camshaft?
If so the first job is to check the drive tag is not badly worn and slipping?
e600
Postby e600 » Fri Jul 08, 2011 11:09 am
Its a series 2, therefore the coil drives the rev counter. I guess you have a ballast resistor type coil being series 2, just check your replacement coil is the correct voltage.
Pat
piman
Postby piman » Fri Jul 08, 2011 3:24 pm
Hello Frogeyeman,
what type of tachometer is it, if Smiths either RVI or RVC, the designation should be on the face of the instrument? RVI can be problematic with Lumenition ignition and their answer is to replace it with an RVC type, or revert to good old fashioned points?
frogeyeman
Postby frogeyeman » Fri Jul 08, 2011 11:21 pm
Hello Frogeyeman,
thanks for your reply.The rev counter is the later type driven from the impulses from the coil
frogeyeman
Postby frogeyeman » Fri Jul 08, 2011 11:24 pm
Pat
Thanks for your reply.The car does not have ballast resistor according to wiring diagrams.The original coil is 12v as was the new one
frogeyeman
Postby frogeyeman » Fri Jul 08, 2011 11:28 pm
Hello Frogeyeman,
The rev counter is made by Smiths but will check to see if RVI or RVC.Should have left well alone as it was all working before coil change.
