My 4.0 XJS Celebrations ariel stopped working over the winter, I suspect a blown fuse but can't find which fuse it is, before I check all the fuses in the car does anyone know which fuse box I need to look in?
Many Thanks
Rod
XJS Celebration Ariel not working
Re: XJS Celebration Ariel not working
Rod,
My guess (and it is just a guess!) is that it won't be a fuse. Even if it is the fuse, it has failed for a reason ie that the current load exceeded the fuse rating and therefore there's a problem somewhere. I think the ICE is controlled by something like Fuse 6 & 7 on the RH underdash fusebaoard.
The aerial insert on late XJSs can be prone to failing but can be replaced without replacing the whole aerial unit. If it is the insert, you can source it easily on ebay or similar but make sure you get the right type. There are two types of aerial - a four section unit or a five section unit.
You could try putting a 12volt feed direct to the aerial and see if it operates. If it does work, remember to disconnect the current when the aerial gets to the top (or bottom).
The last suggestion is that you buy the service workshop manual which is an absolute must for anyone running one of these cars. See the part number and the link to the club shop on the XJS Forum page - "Running an XJS"
I hope that helps. Good luck with sorting the problem.
Not sure which year the Celebration came in? Was it '95?
If so then it may be fuse 5 on the right rear fuse panel. If the year is earlier then it may be fuse 3. Either way it should be a 10 amp one.
Al McL
Rod
Should your mast be u/s I have a brand new genuine item from Jaguar Classic Parts that I didn't use. It's at work so I can't check the part number at the mo. Not sure if its four or five section but it's for a 95 car.
Should you need it I'm sure we can have a deal
TonyS
TonyS
