warning for any one with twin hs6/8 carbs
simon4253
Postby simon4253 » Thu Dec 24, 2009 4:13 pm
I recently had a friend,s very pretty, rust free(south african import) series 2 to tune and fettle after a long lay up. It had been mot'd but ran rough at idle and handled "interestingly". someone had removed the overflow pipes from the carbs and when the front one flooded due to dirt in the float bowl it overflowed straight on to the distributor! the resulting fire resulted in some very fast movements to extinguish followed by a few hours replacing the carbs, distributor,coil and engine wiring loom! luckily I had all these bits and have used hif carbs with central lowdown overflow which copes better with infrequent use and lack of maintenance which this particular car suffers! The owner does like it but knows nothing about cars and usually phones when something is wrong! anyway do check the existence and condition of your overflow pipes occasionally as the result is shocking and time consuming to rectify at best!
1984 daimler sovereign 4.2,1984 jaguar sovereign 4.2 manual,1985 jaguar sovereign v12, 1992 jaguarxj40 4.0,1967 daimler v8,1962 rover p5,1972 triumph 2.5pi, 1973 2000,1971 toledo 2door,1967 1300fwd,1972 austin mini
