UK Vehicle Excise Duty
TerryBeck
Postby TerryBeck » Mon Jun 28, 2010 4:08 pm
I've just received the July edition of the Magazine, which contains some information on UK VED. It says the new rate for the X Type 2.0 litre diesel is £125, but I have just been charged £155 for mine. When I queried it with the DVLA, they assured me £155 is correct. Is there a mistake in the magazine, or should I take it up again with the DVLA?
tont1962
Re: UK Vehicle Excise Duty
Postby tont1962 » Sun Jul 25, 2010 5:15 pm
hi if you check with vca carfueldata.org.uk you will find the 20d comes under band f as it is 149co2 which is £125, the 2.2d is band g £155
tont1962
Postby tont1962 » Sun Jul 25, 2010 5:19 pm
hi if you check with vca carfueldata.org.uk you will find the 20d comes under band f as it is 149co2 which is £125, the 2.2d is band g £155 also check on your log book as you mite find it was registered as 154co2 as was mine and i had to get a letter from jaguar to send to dvla and have it changed as the garage hade made amistake.
