I'm thinking o buying a 2.5 or 3 litre X type estate however my son, who has a 2.5 saloon is experiencing excessive front tyre wear on the inside edge of both tyres. He has had the tracking checked which was fine. I understand that this is a known problem so my question is - Is there a known solution? If not what mileage can I expect from the front tyres?
FuzzyVeggy.
Tyres
It seems to be a common problem on executive cars such as the X Type. However, experiences of JEC members do differ. One member with a 2.5 AWD X Type fitted with the 16" wheels and 205/55 P6000 tyres was getting 30,000 miles from his tyres. The same person with an AWD 2.5 sport on 225/45 P Zeros only got 15,000 miles or so. As for myself I got 16,500 miles from my P Zeros due to wear on the inside edges.
I have produced an article for the X Type Forum on tyre wear which should be appearing in a couple of months in the magazine.
In the meantime buckMR2 has set up the front wheel alignment on his X type as paralell instead of toe out (as Jaguar recommends) and has no tyre wear on the inside edges. I should add that Jaguar give a wide tolerance in their X Type alignment settings and buckMR2's suggestion is within the Jag tolerance.
John Spiller
X Type Forum Co-ordinator
John Spiller
Tracking
who has checked you tracking if its not a dealer then they will have set it to the wrong settings jaguar have changed the specified settings i personelly set x-types to 0.25 to 0.5 mm toe in and have had no comebacks.
Another reason why visiting a dealer is ALWAYS the best option
FuzzyVeggy
