hi my 3.2 sport has blown bulb any idea how to remove lamp please .
front fogs removal
If i remember rightly first remove the inspection panel at the corner of the spoiler , there's about four or five screws holding it on , then you'll see underneath the lamp one screw in the middle , that's the only one holding the bottom .
It's not really a screw in the true sense of the word , it only turns about half a turn and it's undone , you'll find there's two on the top exactly the same , they're a bit of a fiddle to get a driver on and it's probably easier to take out the side indicator lamp for access to the heads of the screws ,
assembly is the reverse as they say
Derek..
Derek..
'93 Daimler, 50,000mls solent blue
'93 Daimler 154,000mls Westminster blue
'85 Rover sd1 2600 vanden plas oporto red
