Courtesy light not working
Ejay
Postby Ejay » Sat Nov 07, 2009 11:29 pm
The courtesy light from my rear drivers side door is not working, all other doors are fine and operate the lights perfectly, however I cannot find the switch in order to try and rectify the problem, any guidence please??.
robv12
Postby robv12 » Wed Nov 11, 2009 11:16 pm
the light is operated by a micro switch in the door locking mechanism, the fault can also be caused by a broken wire in the loom where it links through from the b post to the door
Ejay
Postby Ejay » Thu Nov 12, 2009 6:18 pm
Thanks Rob, just a little nervous about removing any trim, I may leave it until it's next service at the Jag Centre!!
robv12
Postby robv12 » Fri Dec 11, 2009 11:52 am
how did you get on???
