memory seat problems
johnbees
Postby johnbees » Sat Jan 17, 2009 8:30 pm
Hi everybody,just wondering if anyone else has had the problem of the memory seats in their xjr not sliding back when the key is removed from the ignition also the steering wheel doesnt lift automatically either.All the these functions work fine when you adjust them with the buttons manually.Wonder if its a fuse or control unit Would appreciate any help with this problem Cheers John
robv12
Postby robv12 » Fri Jan 23, 2009 10:52 pm
John, my guess is the ECU under the seat hs failed or got water in it at some point, my XJR passenger seat did the same thing, about 25.00 for a secondhand one, i'll check out the part no for you if you want
Rob
