boot fitted cd autochanger
mikehanham
Postby mikehanham » Tue Dec 23, 2008 9:45 pm
just purchased a cd player DBC5130a for a x300 sovereign came with a round plug
can only find a oblong plug 12 pins in the boot ,
do i have the wrong player for my car
any rely would be gratfully received
thanks mike.h
DEREK1951
Postby DEREK1951 » Sat Dec 27, 2008 10:43 pm
Typing in dbc5130 in to the jdht website brings up disc player for a series three v12, but your number has an ' a ' suffix which might mean something else intended for x300's which of course doesn't come up on this site,
I'm not sure but i thought early x300's had the round din connector and later ones used a more up to date fibre optic link, i would say you need a more modern player , give your local dealer a ring with your vin no and they will tell you instantly,
Derek..
'93 Daimler, 50,000mls solent blue
'93 Daimler 154,000mls Westminster blue
'85 Rover sd1 2600 vanden plas oporto red
robv12
Postby robv12 » Sun Jan 04, 2009 1:28 pm
ok, depends where your CD changer should go, most 300's have them located under the rear parcel shelf, remove the boot back board/carpet and you should find a lead with an 8 pin din plug on the end of it, this should be located at the right side of the boot
If you have a late 300 (sorry don't know the VIN no) it will be located on the left hand side boot floor, remove the left hand side carpet and again you will find a lead with an 8 pin din plug on the end, this id your cd lead
As I understand the above change came in in late 96 with the intro of the XK8 which uses the same CD changer and radio if standard audio pack was fitted
I have in the past had problems with interchangeability of these CD changers, they all work in XJ40's but some will not work in late X300
Send me the last 6 digits of your VIM by pm and I'll check it out for you
mikehanham
Cd autochanger
Postby mikehanham » Sat Jan 10, 2009 5:17 pm
thanks for your reply. My car is a very early model x300 sovereign first registered 18/10/94. The VIN number 725536.
The PM reply wasn`t working.
robv12
Postby robv12 » Fri Jan 23, 2009 10:47 pm
you will need a late Xj40 style changer part no DBC 10432 or an early 300 one part no LXF 4160CA (i have these)
These are both Alpine units branded Jaguar
Failing that there is an Alpine on that is a straight plug and play, I have some of these here too
Your car is quite early, but the first 300 was 720001
Evna
Postby Evna » Sat Feb 14, 2009 9:06 pm
Hi Rob,
saw in the thread regarding CD Autochangers that you possibly have some units... I am looking for a replacement for my X-300 3.2Sport
VIN: 812084
My car didn't originally have the autochanger but I found that it was fitted with the cable and Din plug for one so I purchased one from Ebay for £90... It worked for about 12 hours all in all and then gave an error code on the head unit and died!!
Took it to a dealership who managed to salvage the CD that had got jammed inside the player, but informed me that the unit was unservicable, which was later verified by a local radio/electrical repairer. I contacted the guy I purchased it from who promised a replacement then promtly changed his contact details and left ebay... go figure!
Thus I am now on the lookout for another unit to hang on the brackets...
Just wondered if you have a compatible unit
Ian Evans
1998 - XJR Supercharged
With original Nikasil Engine 84,000mls (to Nov 2016)
Pacific Blue Metallic
robv12
Postby robv12 » Wed Feb 25, 2009 3:37 pm
yes i do, pm me and we can discuss
Evna
PM's ???
Postby Evna » Thu Feb 26, 2009 6:13 pm
For some reason the PM function doesn't work... I just get this message each time I try.
Ran into problems sending Mail. Response: 554 : Recipient address rejected: Relay access denied
DEBUG MODE
Line : 152
File : /home/fhlinux150/j/jec-xj-forum.org.uk/user/htdocs/xjbb2/includes/smtp.php
Users browsing this forum: No registered users and 14 guests
