DIRECTION INDICATORS FLASHING @ DOUBLE SPEED
goughy
Postby goughy » Mon Oct 27, 2008 6:19 pm
THE O/S INDICATORS OF MY 1995 X300 DAIMLER DOUBLE SIX ARE FLASHING AT DOUBLE SPEED AS IF THERE IS A BULB OUT!
THE 'BULB FAIL' WARNING ILLUMINATES WHENEVER THE O/S IS SELECTED BUT ALL BULBS ARE WORKING.
DOES ANYONE HAVE ANY SUGGESTIONS OF WHERE TO LOOK?
ANY HELP WOULD BE APPRECIATED.
jagtech
Postby jagtech » Wed Oct 29, 2008 8:32 pm
Most probably the bulb failure module has failed
goughy
Postby goughy » Thu Oct 30, 2008 1:45 pm
If the 'bulb failure' module had failed would this juat affect one side?
goughy
Direction indicators flashing fast.
Postby goughy » Wed Nov 05, 2008 1:24 pm
There is a new development on this; I have realised that the hazard flashers only flash at double speed with the ignition ON. When the ignition is turned OFF the hazards flash normally. Someone please help.
robv12
Postby robv12 » Wed Nov 05, 2008 7:17 pm
I agree with jac tech, I reckon a bulb failure module has failed, it will be the one on the side of the car where you have the double speed flash, and probably the front one, these fail on a regular basis on XJ40, but are better on 300's but they are all getting old now. Either replace it with a known to be good secondhand unit from one of the well known breakers, NE Jag Spares, Euro Jag, Mac Millans etc, or open it up and check for and repair any dry joints you find, personally for the time and trouble I would just replace it
goughy
Indicators flashing speed
Postby goughy » Sat Nov 15, 2008 10:38 am
Thanks robv12
:? Please can you advise where to fing the BFM? I have tried changing the large module in the boot, near to the battery, with three 'known to be good' units and none of them made any difference! is there more than one BFM & where are they sited? :oops:
robv12
Postby robv12 » Mon Nov 17, 2008 10:57 am
there are two BFM's, front is LNA 2240AA and rear LNA2245AB
there are two of each module on the car located at the front behind the headlights, i would go for the front ones first, the rears are in the boot
hope this helps
goughy
Postby goughy » Thu Aug 27, 2009 4:56 pm
I have solved this!!!!
loose multi-plug connection through the R/H footwell sidewall.
Happy days.
:lol:
