Stainless Steel exhausts
chrischapman
Postby chrischapman » Wed Dec 05, 2007 9:54 pm
I am considering the fitting of a SS exhaust to my Mk2. I would like to hear others opinions of the Bell verses Falcon (Falcon standard and straight through) which are available from the two well known parts suppliers that advertise in the club magazine. Thanks Chris :)
PeteB
Postby PeteB » Thu Dec 06, 2007 7:30 pm
We use Bell exhausts (no relation) exclusively, as - in our experience -their products seem to be better made than most, and also tend to be a better fit.
Peter Bell
petticd
Postby petticd » Wed Sep 10, 2008 1:39 pm
I have recently been conemplating the same, however, "Hayward & Scott" was reccommended to be best of all. They are somewhat more expensive however, the quality is better (I'm told). I visited their site and was taken around the workshop - products look very good. These guys also supply a well known restoration company in Maldon and are also listed in the JEC magazine.
I finally bit the bullet and ordered my system 3 weeks ago, can't wait to fit it!
chrischapman
STAINLESS EXHAUST
Postby chrischapman » Wed Sep 10, 2008 3:22 pm
Since my post on this subject I have followed Pete Bells advice and fitted the Bell system (no relation). I found it easy to fit and initially I was disappointed by the sound but now I am used to it. It does not detract from performance as far as one can tell by driving. It's probably better for being quieter because loud exhausts are waring when driving over longer distances.
petticd
Postby petticd » Tue Nov 18, 2008 8:54 pm
I did fit the "Hayward & Scott" system, including thier SS 6 branch manifold. Very pleased with the product, the quality/fit is excellent. I did have to modify the silencer bracket slightly. I too was disapointed by the noise, completely different sound (louder), as much to do with the manifold as the 50 mm exhaust system itself, however I am getting used to it!
nj_brown268
Re: Stainless Steel exhausts
Postby nj_brown268 » Sat Jan 16, 2021 8:41 pm
Just had my (300hp) mk2 on a Dyno, and the exhaust is getting red hot.
I have been advised to change it to a s/s sports exhaust, with manifold.
Thoughts?
nj_brown268
Postby nj_brown268 » Sat Jan 16, 2021 8:42 pm
Thoughts?
piman
Postby piman » Sun Jan 17, 2021 9:20 am
Hello NJ,
changing the material won't affect the temperature of the manifold.
One thing to check is that the ignition timing is not retarded and\or weak mixture as that also will run hotter, as this can increase the manifold temperature?
nj_brown268
Postby nj_brown268 » Sun Jan 17, 2021 3:24 pm
Thanks Alec.
I was under the impression that the exhaust on a standard 3.8 was quite restricted, causing them to run hot.
The idea behind fitting a sports exhaust and manifold was to reduce back pressure in the system?
But I will get the garage to double check the mixture and timing.
PPV
Postby PPV » Tue Jan 19, 2021 12:38 pm
One way to keep the under bonnet temperature down is to have the manifolds sprayed by Zircotec. They come highly recommended by Practical Classics in the past.
Perhaps worth a look.
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
