cooling system warning light
Moderators:robv12, DavidEm
gazco123
Postby gazco123 » Mon Jul 19, 2010 12:31 pm
hi everybody, i have a problem with the engine coolant warning light on my 1998 model. under hard accelleration the light comes on for a few seconds then goes out, the tempature gauge remains normal. i have checked coolant and oil levels and all seem normal, the performance is not affected but it is causing concern, has anyone experienced this problem many thanks
bmc123
Postby bmc123 » Mon Jul 19, 2010 1:26 pm
if all levels are fine, and everything seems ok it might be just a case of a loose sensor wire (the clue here is it happens under acceleration)have you checked all the electrical connections ?
Also, just as an aside and you may think I'm nuts but get your battery checked - a battery on its way out causes all sorts of weird and wonderful messages and lights to appear on our cars and is often discounted by many at the time only for them to discover later (after a lot of time and money spent on other things) that it was the battery after all!
gazco123
Postby gazco123 » Mon Jul 19, 2010 6:58 pm
hi, thanks for the advice i have checked the connection on the coolant tank all seems well,i will get the battery checked tomorrow
danr
Re: cooling system warning light
Postby danr » Sat Jan 12, 2013 4:44 pm
Try battery mate, i kept getting various error messages including the horrible restricted preformance messags on my 1998 x308, Replaced battery and all is well now :-)
Postby J44EAG » Sat Jan 12, 2013 10:03 pm
Multiply posts on batteries under "electrics" on the S-type BB.
