Central Locking - Car won't lock - please help me
Moderators:robv12, DavidEm
Growler
Postby Growler » Sat Aug 22, 2009 7:12 pm
I have a Jaguar XJ8 V plate 1999
My problem is the remote locking will not work from the key fob, so I tried changing the batteries and checked and cleaned the fob contacts but no change and no access.
The doors will lock when the car is running when you put the car into drive or reverse but will not lock with the key in the driver’s side door lock or as I have said above with the central door locking remote.
If you do force the lock down and then shut the door so all the doors are then locked, the key in the driver’s door will not open the doors, after a certain amount of time and jiggling the ignition key in the door lock the windows will lower and you can then open the doors via the internal door handles.
I have applied WD40 to the lock and much thought to the problem but other than dismantling the door and replacing locks etc I am not sure whether there is a way to solve the problem that the guys and gals on this forum have tried and successfully sorted the problem.
Please help.
joejag308
Door locks and things
Postby joejag308 » Mon Aug 24, 2009 9:59 am
Growler we do have a section under Security covering the door locking ect on the 308 if you go to it and click on the title it will bring up all the previous solutions and rectifications.......your problem could be in there......joe
