My ECM is FUBAR !!!!!!!
Moderators:robv12, DavidEm
Postby Brakebuster » Fri Feb 20, 2009 8:11 pm
yup
came back from Jaguar tonight with the news my ECM isnt working correctly
no output on EM85 pins 1&2 on the ECM
throwing codes
P0135
P0155
P1646
P1647
its not switching the output to the two upstream O2 sensors , and as a result the car is over fueling , and therefore failed the emissions test
anyone know of a good ( and cheap as possible ) ECM repairer ?
Mike1932
Postby Mike1932 » Fri Feb 20, 2009 10:00 pm
I may be well off beam BB, but would http://www.autologic-diagnos.co.uk/products/jaguar.htm deal with that sort of thing?
Good luck anyway!
Postby ptjs1 » Fri Feb 20, 2009 11:20 pm
BB,
Don't know if they'll be able to help you, but I've used these guys twice in the last 10 years:
http://www.carelect.demon.co.uk 01983 281811
It was a guy called Rob who set the company up, don't know if he's still running it.
I found them when I had a prob with my Range Rover seat ecu many years ago. Even Range Rover independents wanted £400+ for a new ecu. Rob told me to send my ecu to him with a cheque for £50. 36 hours later, I had it back fixed. Great service and cheap.
Most ecu probs usually revolve around corrosion if exposed to damp, or dry joints if mounted inside the car. If this is your prob, then these guys might be able to help. Don't know if they specifically know much about Jags but got to be worth a call?
joejag308
ECU ?
Postby joejag308 » Sat Feb 21, 2009 10:56 am
BB......Paul Grantham one of our experts is the JEC and Jaguar diagnostic expert hes the one that teaches all others the in and outs of diagnostics.
A very busy guy but if hes in hes the one.........seeing how you have the codes its throwing out...e mail only im afraid.......
paul.grantham1@ntlworld.com ......Joe
BrianG
Postby BrianG » Sun Feb 22, 2009 7:00 pm
BB,
Just my two pence worth: codes P0135 and 0155 are ideed for upstream O2 sensor heaters, banks A and B failure, however I would be surprised if both ECU output stages have suddenly popped. Have you checked that the O2 Heater relay is actaully providing a decent +12V power to the common pin E85-03?
1969 Triumph Daytona rider
Previous XJs:
X300 3.2 in Spruce / Barley
