Nikasil engines, Which cars are at risk?
Moderators:robv12, DavidEm
daveji
Postby daveji » Thu Feb 19, 2009 11:37 am
The following information is reproduced from the April 2006 issue of
Jaguar World magazine.(I hope they have no objections !)
Nikasil bore coated engines considered to be at risk by Jaguar
All V8 cars with VIN Numbers prior to
XJ..........878717
XK.........042775
S-Type...L31320
Nikasil bore coated engines NOT considered at risk by Jaguar
V8 cars with VIN numbers between
XJ..........F00103 to F20644
XK..........A00116 to A11139
S-Type....L31321 to L86901
Steel-lined engines:
All V8 cars from VIN number
XJ..........F20645
XK.........A11140
S-Type...L86902
The above VIN numbers apply to all V8 engines,
3.2 and 4 litre,supercharged and naturally aspirated.
springelec
New Engines ?
Postby springelec » Mon May 04, 2009 5:31 pm
Hi Dave,
This VIN data has proved really useful for me in my search for an XJR.
However, any idea how we can check the build of a replacement engine.
I've found a car that had its engine replaced after 60K miles but with what ?. Another Nikasil engine or a standard one. Who knows ?.
Is there a register we can interrogate which lists Nikasil engines against steel lined engines ?.
Springelec
Postby Brakebuster » Mon May 04, 2009 6:13 pm
engines were usually replaced with another Nikasil engine,
later, when it was recognised that it was the Nikasil that was failing, Jaguar outsourced the faulty engines to have a steel liner installed, these were then used for exchange, and fitted by Jaguar........
a replacement engine will carry a yellow tag mounted under the throttle body, this can be seen in situ looking from above in the engine bay
the engine number ( which has nothing to o with the VIN ) can be broken down into the day and time of production, the code is easily found on the forums
springelec
New Engine ?
Postby springelec » Tue May 05, 2009 1:41 pm
Thanks BB,
I'm trying to get the new engine number asap.
I know I'm being a bit lazy asking this, but where are the engine codes stored in the BB ?.
I also read your comment about Nikasil pressure tests and I agree there isn't a simple black and white figure.
The whole problem can only be described as various shades of grey from pure white to black; white being good of course and black; bad.
However, with so much opinion out there, it is difficult for a newcomer like me to distinguish between the good and the bad.
That's why newcomer's rely upon the views of experienced members like yourself and David Marks, without whom we would probably make a disasterous financial mistake.
So thanks for all your help and advice. It is very much appreciated.
Springelec
Onedrew
Postby Onedrew » Sat Nov 14, 2009 6:42 pm
I am trying to find the various engine no. prefixes eg DC for X308 models Any clues?
joejag308
Onedrew problem
Postby joejag308 » Sun Nov 15, 2009 3:57 pm
Onedrew.............maybe a post to
david@davidmarksgarages.co.uk .........asking exactly what you require would solve your problem..........he will reply, not instantly but at the next time he reviews the posts...........its the best way to get what you require
Joe
