Hi, I've owned my XJ8 for about 9 months, it's my first Jag and it's great!
I’m having problems with my wipers, they switch on OK but when I turn them off, they continue for another 10 to 20 wipes, they then don’t park, on about the fourth attempt at switching them on and off they’ll park.
They’re generally erratic, I understand it’s a problem with the wiper motor, (can anyone confirm this?) I believe a new Wiper motors about £400.00.
I guess eventually a second hand motor will give me the same problem.
Is it possible to fix this or anybody got any ideas?
Wiper Motor
Thanks for the help
I’ll get a second quote for the wiper motor, £90 is a lot better than £400.00 (that was at Rybrook’s of Chester).
The micro switch option sounds even better, John mentioned he’s posted details about replacing the micro switch in the X300 section of jaglovers, where do I find X300 jaglovers?
Sorry I’m new to the forum
Don
Don
Yes, I changed the Wiper motor micro switch, not such a big job and very rewarding when it all works.
Once the motor has been removed, lift off the cover, there’s no need to disturb the wires attaching the lid to the motor, just pull the lid back carefully.
On my Wiper motor the micro switch just pulled off, you need to disconnect the wires from the switch and push the new switch on, soldering the two connections.
The new micro switch had three connectors, I broke the centre one off and it works fine.
Don
Don
Hi Folks,
I discovered the wiper motor microswitch problem about three years ago and posted a fix on the "Jaglover's" web site which was that you don't necessarily have to replace the microswitch.
Mine conked out in the rain going up to Brum for the JEC XJ8 factory seminar in 2005: I fixed it by using copious quantities of WD40 injected into the switch at all the nooks and crannies. It's worked perfectly ever since.
(I bet that's tempting fate !!)
1969 Triumph Daytona rider
Previous XJs:
X300 3.2 in Spruce / Barley
Previous XJs:
Recommended Suppliers List
Gents it does help if you enter your location in your profile, we do know then where you are and to be able to give you the nearest Specialist / dealer best for you ........it does give you opportunities to ring round and get things like prices and details of jobs you need doing ....so please enter the locations in your profiles..........also you are becoming very shy in sending your pics of your cars ....are you ashamed of them?....enter them in the Register and be proud to do so....Joe
