It would be helpful if you select the appropriate word from the Title to use as the Subject in your reply.
Take a look... here
Water Pump and Thermostat
Water Pump
Best advice seems to be that it makes sense to upgrade the Water Pump and change the thermostat at the same time as tensioners are changed.
The parts are not very expensive and its worth the money for the peace of mind.
