Fluid Leak Left Side
teckwing
Postby teckwing » Fri Mar 19, 2010 9:03 pm
I am a new club member and recently purchased a nice 2000 XK8 convertible.
I have notice a puddle on the floor just under the left side just in front of the left rear tyre. It does not smell like gas or oil but could be hydraulic fluid possibly for the top mechanism.
Looking under I see a line with 3 brass fitting. The wet spot is in this general area and also further up on the floor panels.
Any thought would be appreciated.
Tom Ryan
daveji
Postby daveji » Sat Mar 20, 2010 9:23 am
I cannot comment on the location of the puddle but if its clean water its most likely from the aircon condenser drain. Quite usual if the car is left standing after use.Be careful to be sure what the fluid is before getting worried !
Postby mike020150 » Sat Mar 20, 2010 3:14 pm
If you cannot be certain that the fluid is water (from the aircon system) it would be as well to have someone else check and give you a second opinion. The other likely fluids in that area are petrol and brake fluid; the escape of either could cause a life threatening situation. Mike.
teckwing
Postby teckwing » Sat Mar 20, 2010 4:16 pm
Thanks. I will double check.
HeLLCaT
Postby HeLLCaT » Sat Mar 20, 2010 6:20 pm
bloody hell mike you dont mince your words, straight to the point lol :lol:
dont worry mate, i have a similar problem i put a drip tray under the it only to find out after a taste test that it was just water (dont taste it , its vile like someones rotting foot thats been baked :oops: )
turns out its a drain for the air con , well at least thats what the jag dealer said , it might be something more though :shock: , i'll look for you in the obituaries :lol: :twisted: :lol:
Postby mike020150 » Mon Mar 22, 2010 9:53 am
Having found myself partially or completely without brakes on a number of occasions over the years and survived to tell the tales, I've never found these incidents to be positive experiences. Others may not be so lucky. Hence, IMHO, there's no room for ambiguity when it comes to the basic safety of brakes and similar areas. If you're not sure, you can do a lot worse than asking someone who knows the answer, even if it means paying a Jaguar Dealer. Better to be safe than sorry. :) Mike.
teckwing
Postby teckwing » Mon Mar 22, 2010 7:20 pm
Good point Mike. The fluid is not water, it does appear to be brake fluid. I will have a professional check it out. Thanks for the advice. :D Tom
HeLLCaT
Postby HeLLCaT » Tue Mar 23, 2010 11:19 pm
just trying to inject some humour mike , no harm no foul :wink:
i found a bolt under my xkr a few days back so does that mean i need a full engine overhaul? :) :wink:
Postby mike020150 » Thu Mar 25, 2010 10:19 am
If it's the one which looks like a sump plug, the answer to your question is yes! :lol:
HeLLCaT
Postby HeLLCaT » Thu Mar 25, 2010 1:13 pm
uuummmm the what now ,.....engines have oil plugs???? :wink: :lol: :lol: :lol:
teckwing
Postby teckwing » Wed Apr 21, 2010 5:20 pm
Thanks for all the replies.
My mechanic checked it out last week and said that it is hydraulic fluid from the convertible top mechanism. So he suggested checking the level every so often as this was the first time the leak was noticed since the top had not been operated in a while. 8)
Postby mike020150 » Mon Apr 26, 2010 10:27 am
The hood hydraulics do not leak on these cars unless there's a fault. If you decide to run the car in this condition, ensure you are familar with the manual hood closing procedure (it's in the handbook) and the location/operation of the valve key. I'll bet a pound to a penny that it will fail to operate hydraulically when it's raining! Mike.
teckwing
Postby teckwing » Wed Apr 28, 2010 3:11 pm
OK, good advice Mike. I will check this out further. In the meantime I will keep my unbrella handy! Tom
Postby mike020150 » Thu Jul 01, 2010 11:25 am
The hydraulic rams (hood lift cylinders in Jaguar parlance) can be replaced. The back seat and quarter panel trim have to be removed for good access. Don't forget to replace the o rings on the hydraulic connections while you're there. Mike.
