I am getting a "Battery not Charging" error message
It appears at about 2500 RPM and the car goes into limp home mode
Restarting the car clears the fault and the alternator charges at low revs, this is not a normal alternator failure can anybody explain this behavior.
97 XK8
Alternator
Hi Deltasierra,
Due to its extensive use of electronics, the XK8 is very sensitive to battery voltage and many of us have experienced low voltage symptoms like window memory failures. I would speculate that the car also has high voltage protection built into some circuits. I.e. under the circumstances of excessively high voltage, like a voltage regulator malfunction, there will also be default settings to protect sensitive circuitry from high voltage spikes. Consequently, I would have the car's alternator output checked. Mike.
