Rear shocks for 2003 XKR
Jonathan3004
Postby Jonathan3004 » Sat Jun 13, 2009 9:01 pm
I have a ratttle coming from the back of the car and was told it would be the bottom bushes of the shocks. Having spend a considerable time changes the bushes, the rattle is still there!! I therefore assume that I may need new shocks, how can you tell if they are the problem as they looked OK are weren't leaking??? Thanks Jon
Postby mike020150 » Tue Jun 16, 2009 10:04 am
Unfortunately, rattles from the rear shocks are a common problem from a little as 20,000 miles onwards. I think the CATS items may be worse than the non CATS versions. The rattle doesn't seem to affect the damping performance but it sure is annoying! Mike.
Nik
Postby Nik » Tue Jun 16, 2009 9:59 pm
Hi Jon ,
Agree with Mike :wink: BUT are you 100% sure it's the shock absorbers and not something simple like ........... Handbrake cable/linkage.......... rear silencer baffles.............. something loose in the boot or tooltray.................. or as was in the case of my car and found by accident whilst upgrading to jewel lamps ..... a loose bootlid striker plate :!: :? It had been causing a small rattle for three years ,
Hope this helps ,
Nik
Jonathan3004
Postby Jonathan3004 » Wed Jun 24, 2009 11:00 pm
Thanks, I am going to go through everything tomorrow night with the help of a friend. I have already removed everything from the boot and renewed the ARB drop links, shock bushes and all of the bushes in the cross frame. When I push down the rear end of the car and quickly release softly I can hear the noise, I think it might be something connect to the torsion bar, I will get to the bottom of it!!
Regards Jon
Jonathan3004
Postby Jonathan3004 » Thu Jun 25, 2009 9:57 pm
Been through everything I can see but still havnt found it. It is coming from the rear but impossible to tell where. I will keep looking, it isnt significant but just annoying!
