Battery Trickle chargers
cjrm1
Postby cjrm1 » Sat May 09, 2009 6:29 am
Looking at the post on battery drain I wondered if it is possible to connect a trckle charger to the battery without disconnecting the battery at all?
I saw one trickle charger and it seemed to suggest that this was possible- a Draper model.
Doesn't overcome te need to replace an ineffective battery, but would save having to disconnect the battery each time.
Any thoughts/recommendations as I know for a full recharge you have to disconnect
MyQuest
Bttery charger.
Postby MyQuest » Sat May 09, 2009 10:04 am
I use a Swedish CTEK battery conditioner to keep my XK8 up to snuff. (About £40 on Ebay).
I connected a fused pair of wires direct to the terminals and ran them out through a rubber bung in the R.H. rear of the boot/trunk. To this I joined the (supplied) waterproof connector that snaps into the CTEK's output cable. I plug the unit into a convenient power socket in the garage.
The beauty of a conditioner is that it automatically monitors and 'tops up' without harming the battery; apparently prolonging its life.
When not in use, I clip the battery cable under the R.H. wheel valance.
I've never had the dreaded 'window drop' since!
Michael
cjrm1
Postby cjrm1 » Sat May 09, 2009 7:47 pm
Thanks My Quest
Went and bought a Ctek today
So you are connecting directly, in effect, to the terminals. On the one i have purchased it says connect the live direct but the negative to the car body not the terminal.
This seems less efficient, but does anyone else have a comment or view?
PrideofLyons
Postby PrideofLyons » Sun May 10, 2009 10:45 am
Just connect directly to the battery terminals. The advice to connect the negative of chargers/boosters to an earthed body part is to avoid the risk of a spark when you make/break contact (as in removing a jump lead once the car has started) which could ignite any gas seeping from the battery, thus blowing the whole lot to kingdom come.
A permanently-connected battery conditioner doesn't present the danger of sparking unless, I suppose, you haven't firmly anchored the connection to the battery post (unlikely) when it's conceivable that plugging/unplugging the charger could jiggle the wire enough to disturb the loose battery connection, possibly creating a spark in which case, all bets are off. This scenario is a bit far-fetched though, ie just make sure the connections to the battery are nice and tight. I've had permanently-connected CTEK's on my cars and bikes for a few years now and everything's fine - I believe that the latest models even boast a 'no-spark' technology anyway.
springelec
Battery Charging
Postby springelec » Mon May 11, 2009 5:02 pm
Hi Everyone,
There's a lot about looking after your battery on various motorcycle web sites because bikers, like me, tend to only use their bikes during the summer months.
Optimate is a well known motor cycle brand which monitors battery voltage level and sometimes temperature to ensure long life.
The only problem I can foresee is the constant drain from the car, expressed in other parts of this BB as anywhere between 10mA and 100mA.
Optimate and similar battery chargers only trickle charge to keep heating losses in the electrolyte to a minimum.
If the trickle charge is say 10mA and your XK8 back ground current drain is say 10mA, then all the battery charger will be doing is feeding your XK8 and not the battery.
Trickle battery chargers are OK, but I think their application needs a bit more thought before rushing out and buying one.
It would be nice if we as an XK8 group could get some battery drain stats from Jaguar or even members. Jaguar should be able to provide some original design information as this would have been part of the XK8 design excersise. Anyone know a Jag design insider ?.
With the benefit of best and worst case battery drain data from Jaguar, we could then specify an optimum trickle charger.
Any offers from members to tackle Jaguar about this ?.
Springelec
PrideofLyons
Postby PrideofLyons » Mon May 11, 2009 5:32 pm
The CTEK offerings aren't trickle chargers - they're battery-maintenance systems that continuously monitor the battery's condition, putting it into discharge mode when necessary then re-charging to full charge on a continuous cycle. Can be safely left connected to a battery indefinitely.
Postby ptjs1 » Mon May 11, 2009 9:51 pm
I've got 3 battery conditioners for my bikes & XJS. They are all models of the Accumate / Optimate series of chargers.
All the Acumax, Accumate & Opimate seem to run output current somewhere between .8a - 1.2a until they get the battery voltage into the 14.2v - 14.9v range, then maintain it there. With that level of outut current , it's more than sufficient to overcome the amps being drawn on alarm / radio circuits.
I also just noticed M&P are selling the Acumax Platinum at the reduced price of £29.99 - great value!
Postby mike020150 » Fri May 15, 2009 2:09 pm
According to Jaguar's service data, the quiescent battery drain (key out, car locked, everything else turned off) should be <30 milliamps one hour after locking. Measurements made earlier than one hour risk being inaccurate because certain circuits remain live for a time. Mike.
springelec
Trickle Chargers
Postby springelec » Sun May 17, 2009 3:44 pm
OK Pride of Lyons, I admit I was a bit sloppy with the use of 'trickle charger' to describe a 'battery conditioner'. These are however, terms invented by their manufacturers to introduce marketing differentiation between themselves and the old style trickle chargers.
My argument remains the same, these devices output low current levels, i.e. trickle current to keep the battery topped up. By way of comparison, many modern batteries will withstand the 10Hr charge test, which for a 1000AHr XK8 battery is 100 Amps/Hr for ten hours ! !. Not many people have access to this type of equipment, so most just use an inexpensive charger or a slightly more expensive conditioner.
Your point about the CTEX device exercising the battery is well made but, to truly exercise a battery, the discharge needs to be very heavy and deep to fuse delicate fingers that can grow across the plates and give the appearance of a shorted cell. I have used this technique successfully on a couple of motor bike batteries and on one car battery to breath new life into the unit.
The technique needs access to a fairly powerful bench power supply with a high current capability. Connect the battery to the power supply and switch on. A shorted battery will naturally take amps and amps, but if it is going to recover, eventually all the little shorting fingers inside the faulty cell will fuse releasing the cell for normall charging.
Fully charge the battery and then discharge violently. A thick screwdriver usually does the trick. Yes there will be sparks and stuff and yes the screwdriver will get hot, but that's the point. The high discharge current fuses any other stubborn filament within faulty cells.
Repeat two or three times and the battery should be OK for another twelve months service.
Interestingly, I've just referred to my Yuasa Battery notes and they also state that heat adversely affects the life of a battery, quoting 90% loss of float life at 50C.
Now Jaguar put their batteries in the boot which is usually a cool space, but all the Eurobox cars put their batteries in the engine bay which during the summer can easily achieve 70C - 80C. Armed with this fact, it's amazing most car batteries actually last more than one season.
Springelec
