Intermittent "heavy " steering
Martin904
Postby Martin904 » Tue Feb 10, 2009 10:55 am
Occasionally the steering on my 2002 XKR feels heavy at low speeds - this often happens after a spell of higher speed driving but not always !
It dosen't last long time but is starting to happen more frequently.
Ther are no no fluid leaks and nothing obvious on a visual check - anybody got any ideas or similar experiences ?
jagtech
Postby jagtech » Tue Feb 10, 2009 9:03 pm
You have what is called servotronic steering on your xk8 the most likely cause is a broken wire from the PAS control module located rh side of dash to the steering rack quickest way to cure is to replace both wires.
If you need someone to have a look for you PM me
Martin904
Postby Martin904 » Fri Feb 13, 2009 11:59 am
Thanks for the information, I am away for a few days but will get that checked when I get back.
