Rear Subframe Bushes
Graham
Postby Graham » Sat Mar 15, 2008 6:55 pm
Hi has anyone had any experience in changing these bushes on a 1991 4ltr Daimler Sovereign.I am experiencing knocking when going over bumps or on uneven roads and on checking under the rear of the car i notice that these bushes look worn out.When driving on the motorway there is no problem.Just a quick note the self levelling suspension has been removed from the car.Regards Graham
2005 Jaguar S Type 4.2 V8 Petrol AUTO
strathmore22
Postby strathmore22 » Thu Apr 10, 2008 1:54 pm
Hello. I have had these symptoms on two separate occasions. I could have sworn that the rattles were coming from the rear but in each case the fault was at the front. The first time it was a shock absorber and the second time it was the links between the rollover bar and the lower wishbone. Each time the fault was cured, so I suggest you check out the front suspension as well. Regards, Roger.
Graham
Postby Graham » Sun Apr 13, 2008 10:10 pm
Hi Roger thanks for the info i will check it out.Regards Graham
Graham
Postby Graham » Wed May 28, 2008 6:04 pm
Rear A Frame bushes have finally been replaced by my local garage.I did try and do the job myself but due to the previous owners neglect on maintaining any lubricant on all the bolts i had to take it to the local garage.The owner being an enthusiast(thank u o great one),did not charge me the going rate of two days in getting the A frame off due to a seized bolt which had to be cut off and re threaded.So my advice for what it is worth is to keep your "rear end" well lubricated.The car now has no knocks or bumps but i have decided to have the rear springs and shocks replaced with the hub bearings just to make sure it all stays ok and while the owner is in a nice state of mind. :lol:Happy motoring Graham. :D
Popsjag
Re: Rear Subframe Bushes
Postby Popsjag » Mon Jan 26, 2015 9:46 pm
How does one refit the bushes into the subframe? Answer - make up a tool to do said job!
How long to make tool? - 3 days (in between work of course!).
How long to refit bush? - less than a minute each side!!
Steve.
2003 X350 XJR - daily driver
Past vehicles:
Postby Brakebuster » Mon Jan 26, 2015 11:02 pm
nice.....
been driving bearings out myself tonight
we just can't get enough , can we , lol
BB :mrgreen:
