JLJE 4133AA £2.94 inc VAT a pair from main dealers
Probably the cheapest 2 items you'll ever buy at your dealer, a simple push on fit.
I had mine fitted to my 96 to cure a slight condensation problem and then had them swapped when I upgraded to Xenon's
To my knowledge Jaguar never fitted these as standard and they'd only be added if condensarion was reported.
Mark
Condensation Cure - elephant trunks part no
MikeDoggart
Very front of the light inside edge so connecting to the indicator part of the light cluster.
I thought a strange place for them to be considering the main condensation is to the main beam but guess that there's not the required space to fit them anywhere closer
There should be a little raised area (which may not be punched through on lights not having the mod) and the trunks fit over this once a hole is made.
Hope that helps?
Mark
Hope that helps?
Mark
GrandTourer
Hi Mike,
I too bought these two little T-piece air vents about 2 years ago (as Marky said: probably the cheapest bits of spare parts you can buy).
I took instructions from the JTIS which are quite detailed. The trouble is my hands were not designed to work in 'very confined spaces', so I decided to mention it to my dealer who offered to fit them for me for nothing (kind people they are - mind you I bought 2 cars from them so far).
The light unit has, apparantly, a small 'closed spigot on the outside which is intended to be drilled throuhg and the T-piece-vent fitted over it.
My dealer told me that my car lights did not have these closed spigots on the light units, so they just drilled a hole through - I don't know where exactly and that seems to have solved the problems.
I have also heard about some cases, that the T-piece air vents don't always work.
Some people also put a little silicon gel bag (usually packed with electrical equipment) into the back of the light unit which should keep it dry. Every so often, they take it out dry them with a hair dryer and replace them for another 6 months or so.
If your condensation is not too bad, maybe that is a solution.
Good luck and let us know, if you solve this problem.
Karl, XK8 MY2000 Pacific Blue
GrandTourer
Weird that Karl as my replacement OEM Xenon lights had the spigot bit as did my 96 originals. Can only guess that the changed the headlight design midway through then changed it back again
M
I agree Mark - but then I have (almost) stopped to be amazed - just think that is 'Jaguarness'
Makes life interesting
M
MikeDoggart
The 'trunks' should certainly sort that out
If you want to read an elaborate solution take a look at he following roadfly link:
http://forums.roadfly.com/forums/jaguar ... 257-1.html
Mark
Mark
Users browsing this forum: No registered users and 15 guests
