Front wheel wobble
Graham007
Front wheel wobble
Postby Graham007 » Sat Oct 13, 2007 7:32 pm
I have an XKR which has very minor wheel wobble on checking the front suspension there is a small amount of play in the off side wheel bearing. Can these be adjusted or does it mean a new bearing.
Regards Graham
Many thanks Graham
Sharfrs2
Postby Sharfrs2 » Mon Oct 15, 2007 11:46 am
New bearing, very probably. Had a similar problem on my 8. Had both front bearings replaced and all was fine.
Remember those that gave their todays for your tomorrows.
MarkyM
Postby MarkyM » Mon Oct 15, 2007 6:12 pm
Yep get both done at the same time. If by chance your brake pads/discs or dust shield need replacing get them done at the same time.
I upgraded all of my wheel bearings (they misquoted the price of the rears at the same as the fronts) and I took along my own EBC discs and pads and brake shrouds which they fitted for free (since they had to take them all off anyway.
Something that's hard to DIY since most people don't have the ABS removal tool.
Bit of a result for me :P
Mark
Postby mike020150 » Tue Oct 16, 2007 2:56 pm
There shouldn't be any discernible play in XK8 front wheel bearings, As Mark says, it's not a diy task unless you have the right kit and (from observation) a long scaffold pole for leverage. Things are very tight. Mike.
Graham007
Postby Graham007 » Sat Jun 07, 2008 7:14 pm
Thanks for the replies it did pass the mot the wheel has a very small amount of play on the off side wheel so will get the bearings changed in the near future you cannot feel anything when driving only when its jacked up.
Regards Graham
Many thanks Graham
