Exterior Window Trim
MikeDoggart
Postby MikeDoggart » Thu Jan 04, 2007 9:37 pm
Hi All.
I have an Anthracite Black coupe and the grey trim on the windows has a couple of small patches where the finish has flaked off. Does anyone know how I can make it good?
Regards, Mike.
Sharfrs2
Postby Sharfrs2 » Sun Jan 07, 2007 2:47 pm
It's a common problem, but I haven't heard of any treatment other than buying new trim :shock:
Remember those that gave their todays for your tomorrows.
peterdyer
Gun metal Grey , Window Trim
Postby peterdyer » Mon Jan 08, 2007 4:51 pm
Hi, Had a simular problem on my front windscreen surround. Got a body shop to , touch-up/respray, whilst carrying out another spray job. they did alright too. Could not see where they blended it in ! Hope this helps. Happy New Year. Peter Dyer. :D
MikeDoggart
Postby MikeDoggart » Tue Jan 09, 2007 11:37 am
Thanks guys. They are only tiny patches so I think I'll put up with it for the time being.
GrandTourer
Postby GrandTourer » Tue Jan 09, 2007 11:27 pm
Hi Mike
the surrounds colour is called Dorchester Grey (don't know part no) and is available from Jaguar Dealers in a touch-up bottle kit form.
Karl, XK8 MY2000 Pacific Blue
MikeDoggart
Postby MikeDoggart » Wed Jan 10, 2007 12:03 pm
Thanks Karl. Next stop - a Jaguar shop!
Mike.
peterdpps
Postby peterdpps » Fri Aug 03, 2007 3:48 pm
I know this is an old thread but I have the same problem, so I shall need to touch up the areas that have peeled. On a related note, it looks to me that the window trim surround is made of stainless steel. Was the XK8 coupe ever supplied with the trim 'bright' rather than painted as it is on the new XK? I think it would probably look good, particularly on a black car. Does anyone know of a supplier?
GrandTourer
Postby GrandTourer » Fri Aug 03, 2007 4:40 pm
To my knowledge it has always been this colour.
I would also think, but not 100% sure, that the surround is actually aluminium, but I stand corrected if someone knows differently.
peterdpps
Postby peterdpps » Mon Aug 06, 2007 8:48 am
Yes, I dont think I have ever seen a UK car with Bright trim but as the US usually have slightly more 'bling' on their cars I wondered what it might be like. It could be aluminium rather than Stainless, i haven't looked that closely. It might mean a session with the touch up paint to bring up to standard.
peterdpps
Postby peterdpps » Mon Aug 13, 2007 3:22 pm
For anyone who has the 'peeling window trim syndrome' on their XK8 coupe I can share the following tip.
Buy an aerosol of Peugeot 'Graphite metallic' from Halfords.
Rub down, prime and spray and you will find it is a perfect match. Even on part lengths of trim you 'can't see the join'
smurf
Postby smurf » Wed Aug 15, 2007 10:59 pm
Thanks for that idea for a colour match, I too have one bad trim which needs some TLC. I'll take a look when in halfords :)
D_Doran
Postby D_Doran » Fri Aug 17, 2007 6:16 pm
Thanks for the advice re Halfords paint. I have a few areas on my 2002 Anthracite Black XK8 which need a bit of attention. I thought it may mean a complete trim replacement, but this may save a fortune, and if it isn't perfect it won't be the end of the world 'cos I'll only be back at the same stage of replacing the trim eventually. Thanks for a very worthwhile tip.
Damian
:D
XK8UK
Postby XK8UK » Sun Aug 19, 2007 6:54 pm
Why use a different makers paint code when you can buy the correct 'Dorchester Grey' Jaguar colour from any good paint supplier (such as CARS) in aerosols, touch up or the full tin? Just don't see the point.
Bas
cjrm1
Postby cjrm1 » Thu May 21, 2009 7:22 pm
Does anyone know how you remove the trim from the top of the door skin so that it can be replaced?
Postby mike020150 » Thu May 28, 2009 5:03 pm
The trim piece unclips after removing the door mirror. Mike.
