burning oil ???
gasman1003
I was at a JEC XK Seminar last year when David Marks commented that it was a fact of life that these engines do use some oil and as long as it isn't excessive this is not a problem.
Sorry, but I can not remember how much he felt was excessive. I have also heard that they will use more if run on fully synthetic oils with grades such as 0W-40 (ie Mobil 1). Do you know what the dealer filled it with?
I run a 2000 MY XKR, use 5w-30, it has 49,000 on the "clock" and uses very little oil.
David Marks is extremely knowledgeabe and if you get no joy from your dealer it may be worth contacting him, if only to set your mind at rest.
Good luck,
Steve.
Good luck,
Steve.
GrandTourer
Hi Stanner,
Mine is a MY00 XK8 which I have owned for just over 2 years and have done about 24Kmiles. The car has now 69Kmiles on the clock.
I guess I topped up with 1.5 - 2 ltr of oil between the two last 10Kmiles services and that seems quite reasonable I feel.
As Gasman mentioned, I used a fully synthetic oil, on recommendation of my dealer, the last time and feel it uised a bit more. I will go back to the traditional 5W-30 semi-synthetic oil as specified in the manuals.
Karl, XK8 MY2000 Pacific Blue
Thanks for your help guys,it is helpful to know some of the facts about owning one of these cars. it behaved perfecly on holiday averaged 29 ish to the gallon and turned heads everywere we went, one of the highlight sof the trip was cruising around with the top down, cant be beaten, filled the boot with a fair amount of wine,and loads of room for all the luggage, very pleased with it to say the least,
gasman1003
Uses oil?
My 1998/9 4.0 XK8 uses no oil between services and is running on fully synthetic ,it is serviced every 5000 miles (6months as I like to look after the old girl ) incidently it is the original nikasil engine and is showing close to 105000 miles !!! all servicing and repairs carried out by the Jaguar Centre in Hull (great bunch of guys and gals and sod the expense!!)
Nik (East Yorkshire)
GrandTourer
Oil Burner
Sorry to disappoint, but as David Marks says, some do burn oil. Mine was down to 900 miles p/ltr, fully synth. Now back up to 1200 miles p/ltr on 10w/40 semi-synth.
Last service "blow-by check" was 13 ltr/p/min. So everything else is OK. Cheers, Peter.
