Hi from Banbury
PaulGover
Hi from Banbury
Postby PaulGover » Mon Jul 19, 2010 8:37 pm
I've been a JEC member for several years, but not used the bulletin boards until now.
My XJS is a 1991 V12 facelift model, in Regency Red. It's done around 100,000 miles, but been up in the air for the last 18 months after failing its MOT.
It's not the most wonderful example - it started going downhill after I parked it in a crash barrier on the A34 - albeit at about 3 mph. Since then rust crept in while I was replacing the front subframe, and the ABS brakes went pear-shaped, and the exhaust started leaking, and the handbrake stopped working, and the tyres need replacing, and its MPG isn't as good as it should be, and the radio aerial doesn't extend, and the windscreen washers didn't, and the air conditioning doesn't, and the power steering leaks, and I need to replace some bushes. Other than that it's fine :wink:
Entente Cordiale people may know the car, and my beard...
steve455
Re: Hi from Banbury
Postby steve455 » Sat Sep 04, 2010 9:22 pm
Hi Paul welcome,
I've had mine off the road for about the same time (now sorted) and they don't like being ignored.
Good luck with the resto
Steve
1988 XJ-S Coupe 3.6
poprivet
Re: Hi from Banbury
Postby poprivet » Sun Sep 05, 2010 11:29 am
Welcome Paul, I know Banbury quite well :)
Re: Hi from Banbury
Postby Brakebuster » Sun Sep 05, 2010 12:32 pm
wow,
that mean white XJS is sooooo bad , that all the other cars have been frightened off, lol
welcome
BB 8)
