XJS Panel Lights and switches conversion project to Blue LED
540itouring
Postby 540itouring » Sun Mar 07, 2010 12:58 am
Hi , just to give you a update of what I have been doing with my
interior panel lighting conversion to blue LED. So far after
replacing the head unit I have replaced the lights in the gear
selector , sport switch , and now the lights in the four light
switches. When I dismantled the lighting switches I could see how
poor they were designed. The standar switch has a dull green
location bulb and a pale yellow light which lights when the switch
is selected. The main problem is that when the switch is ON the
pale yellow and the location green bulbs are on at the same time ,
very poor desing as the swich almost looks white !
I have designed a circuit to drive a bright yellow and a bright
blue leds in each switch but to make the lights clear they switch
over so onle a BLUE or YELLOW is lit at any one time is ever on.
The front fog switch changes from blue to GREEN and the rear fog
goes from BLUE to YELLOW and the interior light switched also go
from blue to yellow. This mod works very well and I will now be
working on the Computer back lighting to change this to blue.
This is a link to the work I have been doing
The computer back lights are now also blue and am experimenting with the computer button lights
http://tinyurl.com/ykolvld
More pics when i do some more soon.
dhdove
Postby dhdove » Sun Mar 07, 2010 10:29 am
WOW :shock:
Nice :P - it's like Star Trek.
Tony
XJS Bulletin Board Moderator
540itouring
Postby 540itouring » Sun Mar 07, 2010 6:28 pm
Now also converted the heated rear window switch to BLUE/YELLOW and the hazard switch to BLUE/RED. The drivers door switch is now blue and so jobs left are passenger door and the instrument cluster which is oin bits on the bench !
More pics have been added to the above link
540itouring
Postby 540itouring » Sun Mar 07, 2010 7:09 pm
New Link of project
http://tinyurl.com/y8f93vx
540itouring
Postby 540itouring » Sun Mar 14, 2010 12:27 am
Fuel guage , volt meter and rev counter now converted to blue neon colour and looks fantastic but i think i will have to dim them a little more. The Blulbs were replaced with 5 white leds , the rev counter has 14 blue leds and the fuel and volt meters have two leds each. More pics have been added to the link.
Almost done ! .....just about another day and the leds will be finished
P.L
Re: XJS Panel Lights and switches conversion project to Blue
Postby P.L » Tue Oct 07, 2014 3:53 pm
Hi 540i,
I am very interested to learn more about that circuit you designed to make the LEDs inside the switches switch over. Looked at the electrics for a while but couldn't figure out how to solve that...
Thanks,
Peter.
1994 XJS AJ16 Coupé Manual
