convertible headlining
Gordonl
Postby Gordonl » Tue Feb 23, 2010 6:13 pm
BEC17245LFJ
I have been offered a new headlining part number BEC17245LFJ
for my car but need to know if it is the right part for my June 94 XJS convertible 2+2 with AJ16.
How can I tell?
Thanks, Gordon
iain1980
Postby iain1980 » Tue Feb 23, 2010 8:48 pm
The part number (BEC17245) according to Classic Parts would fit
"XJS (From (V)179737 Up to (V)226645)"
and
"XJS (From (V)139052 up to (V)179736)"
That is all of them I think!
The trim code (LFJ) part isn't listed.
Go here JCP and type the part number into the search box for confirmation.
Hope it helps
Iain
Postby ptjs1 » Tue Feb 23, 2010 10:31 pm
Gordon,
See if you can find out if the headlining is uncut ie that it is necessary to cut out the recess for the rear window.
The reason I say that is, as mentioned, Jaguar Classic Parts quote the same part number for early and late convertibles. But 2+2 convertibles have a smaller rear window. Therefore, unless the headlining is sold uncut for the rear window, it can not be the same for early and late convertibles.
If you can get a photo, then you'll see if the lining is precut for the window or not.
Also, be warned that fitting a headlining can be quite a complex job. You lterally have to cut out the old one from the hood frames as it is glued in!
Good luck with whatever you decide.
