Engine Fault code FF44
gwheele3
Postby gwheele3 » Tue Sep 29, 2009 2:16 pm
My 1994 XJS has displayed this fault code for several years now. No other symptoms - performance, fuel consumption, noise, emissions - all normal. Three Jaguar specialists in Coventry - where they know a thing or two about Jags - have worked on it - changed catalysts, sensors etc but have failed to track it down.
Surfing the web shows that I am not alone with this problem. There are several postings about it. Possibly to do with Marelli electrics; or Technical Service Bulletin 1857. But no solution.
Does anyone on the BB have any experience to help me?
Geoff.
AJT
Postby AJT » Tue Sep 29, 2009 5:00 pm
Hi Geoff
Is one of those Coventry specialists you've used Chris Boon at Cov Cats?
There's not much he doesn't know
Alan
gwheele3
Postby gwheele3 » Tue Sep 29, 2009 5:24 pm
Hi Alan - Yes it has been to Cov Cats. Also Chris Forbes at CFS; Paul Granville - and I forgot it has also been to Guy Salmon, the local dealer.
Geoff.
almcl
Postby almcl » Tue Sep 29, 2009 8:25 pm
Not experienced this exact code, but has the lambda sensor been changed by any of the experts? And did they try adding an earth strap? What voltage does it actually give while driving?
I stand to be corrected here (way beyond my knowledge level, as usual) but I think this code implies a control voltage outside the limit but have no idea how long it takes to flag a fault.
Al McL
iain1980
Postby iain1980 » Tue Sep 29, 2009 9:54 pm
You probably know this allready but FF44 is the O2 sensor check. It is flagged up when there is no feedback voltage when the ECU applies 12.5% enrichment. It will then try a massive 37.5% enrichment, if there is still no feedback voltage it will flag up this error and default to the map with no correction.
Have you had the emmisions checked - it could be running dangerously lean!
For fault finding I would first replace the O2 sensor, has this already been done?
Secondly I would run all new temporary wires to the sensor from the ECU and reset the error memory to see if it comes back. (It is not a nice place for wires to live, under a car!) Unfortunatly car mechanics seem to think that wiring is infallable!
Does it crank for a long time (relitively) before firing, the fuel pump or fuel pressure only has to drop off for half a second or so, I would check the fuel system if at all suspicious.
Have you had the ECU tested? The best way is to put your ECU onto a good car, NOT THE OTHER WAY AROUND. You might then end up with two dead ECUs!
When I bought my car it had this error code and FF11, (one of the reasons it was cheap :D :D :D )both turned out to be wiring related. If you are having problems, ring me (although I am no Expert!) on xxxxxxxxx. (Number removed on request of the member by davidr)
