XJS and XJ6 springs, interchangeable/same?
masterb
Postby masterb » Sat Sep 12, 2009 10:17 pm
Does anyone know whether the spring and or shocks are the same or interchangeable.
Between XJ6's and XJS's?
I have been offered a set of springs, new for an XJ6, i think they may be the same or would do nicely.
Any Idea?
Ta Paul B. :roll:
P.s. And What if any, is the difference between the springs on or for a 5.3/6ltr and a 3.6/4ltr?
Can you use springs off/for a 5.3? are they the same size? and can you get a stiffer set up using 5.3 springs on a 3.6 if they are different/tougher/stronger. :?: :?: :?
dhdove
Postby dhdove » Sun Sep 13, 2009 6:16 am
MrB
As far as I can tell Jaguar fitted differently rated springs to just about every model AND spec. they made - it's a minefield!
You could try going to the Classic Parts website and put the part numbers into the search box, this will then helpfully list all models that had that part number fitted :D
I do think that we need some further info. on road springs and ratings and what you can actually fit to what so perhaps something for the next XJS seminar?
Tony
XJS Bulletin Board Moderator
masterb
Postby masterb » Sun Sep 13, 2009 9:44 am
ta 4 the reply DH,
What was the full website addr you mentioned was it .co.uk?
There is a few out there.
Pretty sure xj6 rear shocks are the same, seen a few advertised on ebay saying to fit xj6 and xjs.
Also read somewhere that many jags used the same parts, but they had different part numbers for each model?
Which is a bit mad if they actually are the same parts.
I know parts for a audi 80+100 or vw golf will fit my pork924, so i am wondering if maybe some bits of say an allegro will fit my cat?
dhdove
Postby dhdove » Sun Sep 13, 2009 9:52 am
Sorry, Jaguar Classic Parts..........linked from the links on this site above (tho' my link hasn't worked for a while now :x ) OR easy route via JDHT....Parts....then use Search. I haven't heard that Jaguar used different part numbers for the same part depending on model but to be honest nothing would surprise me :roll:
http://www.jaguarclassicparts.com/html/JCPHomePage.html
You could try fitting All-aggro springs, I think you may get quite an attractive "Lowrider" look.
Tony
