Headlight washers.
Ossycat2003
Headlight washers.
Postby Ossycat2003 » Fri Aug 29, 2025 7:54 pm
I have a 2003 XK8 with headlight washers that are working but the offside one doesn't retract back into place as the washer unit clip has become detached from its fixing point under the headlight.
Does anyone know if it can be re-fixed without the headlight being removed?
Maybe through the wheel arch liner access panel or is it possible to do it with maybe a pair of chopsticks through the aperture where it should retract to .............keyhole surgery style?
Re: Headlight washers.
Postby mike020150 » Sat Aug 30, 2025 9:41 am
Removing the headlamp isn't difficult (3 fixings plus the wheel arch liner clips & the electrics plug), so it's probably quicker to do that than spending time working around the problem. You also need to establish if either of the washer tangs are broken, causing it to have come loose. Mike.
Ossycat2003
Postby Ossycat2003 » Sat Aug 30, 2025 12:47 pm
Cheers Mike .............I'll put the chopsticks away then!
MarkX
Postby MarkX » Sat Aug 30, 2025 1:33 pm
Here’s a very useful video on removing the headlamp.
https://youtu.be/c4chh_m06Sg?feature=shared
If your cover is broken then it’s probably going to be a second hand or aftermarket option as Jaguar don’t seem to have any new ones.
Mark
