Hi all
2006 jaguar xk flagged some sub frame corrosion, does anyone know of any treatment specialists in Midlands area for underneath
Thank you
Rust prevention subframe
Re: Rust prevention subframe
Assuming the warning was meant as advice to stop the situation getting any worse, there are businesses prepared to treat and stabilise any rust before adding a protective coating. The treatments are rarely cheap - typically around £1500. David Marks in Nottingham has been known to carry out this work for customers, as does JR Classics at Askern, Doncaster. Alternatively, why not have a go yourself? Lanoguard is very easy to apply. Or, Dinitrol and Waxoyl can be used with a little more preparatory effort. Of course, all of this may be of little use if corrosion already really requires replacement of the subframes. Mike.
Users browsing this forum: No registered users and 15 guests
