HI All
First post and unfortunately is because of an issue with my 2007 XKR.
I need a replacement Fuel feed pipe, part number C2P14041.
Both myself and the mechanic have failed to find so far. Any help would be gratefully appreciated.
Thank you
Phil
Jag xk 150 Fuel feed
Re: Jag xk 150 Fuel feed
Unfortunately, this situation is becoming more of a problem for early XKs. Jaguar no longer lists the pipe on its parts website which suggests the company does not intend restocking the pipe in the near future. You have two options to recover the situation. Either buy a second hand pipe from one of the specialist Jaguar breakers, like Autoreserve or Eurojag, or take your existing pipe to a local hydraulic pipe specialist and get that company to make you a copy/repair. A Google search will soon reveal a hydraulic pipe repair specialist. These companies are used to providing one-off solutions and are often very helpful. Mike.
Hi Phil have you tried Jaguar Classic parts - they are listing the pipe (Part no C2P14041) at £248.05.
Kind regards
Kind regards
philtaragel855
Thank you, appreciated and very prompt help.
Brilliant!
Brilliant!
philtaragel855
Thanks again but no luck finding the part so looks like will be a manufacturing job as don't think chewing gum or some tape will sort this one!
