Hello, quick tale of woe on my 130 000 mile '94 model 3.2S. It's been off the road for years, but in my garage and on a battery trickle charger. I replaced the crankshaft position sensor about 2 or 3 years ago and whenever I do start it up, it fires up perfectly. Months go by between starts and it's always faultless. Two weekends ago I started it up as usual - fired up instantly - and drove for about 10 minutes around the block, during which time it ran sweetly, until the end of the run, when it developed a misfire, as if it was not firing on all six cylinders.
Anyway, I had no time to investigate so I garaged it and connected the trickle charger. This weekend just passed, I tried to start it up... no dice. It cranks healthily but it will not fire.
Does anyone have any advice, please? Battery is good, electrics generally seem good - no warning lights on the dash... it just won't fire up?
Thanks in advance.
XJ40 Won't Start
Aidan
1994 Moroccan Red XJ40 3,2 Sport ("Ruby")
1995 Jade Green X300 3,2 Sovereign ("Jade") SOLD
2005 Cedar Green Pearl Volvo XC 90 SE SOLD
2002 Toledo Blue BMW 530i e39
Dave Eynon
Re: XJ40 Won't Start
If its been off the road for years how old is the petrol? Stale petrol can cause all manner of problems with filters, pumps, injectors and poor running. If the petrol is the cause it may require a tank flush and all the system cleaning / renewing.
Hopefully it may just be a change of spark plugs to cure your running issue, but the fuel system should be addressed before too long.
Dave E
Gwynedd. N Wales.
X-type 2.5 Estate
XK8 Coupe
XJ 4.2 S1
Daimler 2.5 V8
Gwynedd. N Wales.
X-type 2.5 Estate
XK8 Coupe
XJ 4.2 S1
Daimler 2.5 V8
Thanks Dave.
Yes, after the last run when it was stuttering at operating temperature I did think the fuel might be at fault, as it is old and was reading almost empty. So I put £15 new fuel in and a shot of Redex but it didn't help. Still doesn't start. Of course, old fuel may still be the cause, perhaps the fresh fuel and Redex was too little, too late, but the fact that it fired up as well as ever while cold, and then faltered when warm, and now doesn't start at all is a puzzle to me.
I'll do some more digging, and thanks again for your advice.
Aidan
Dave Eynon
I hope you get it sorted, I do like a 3.2S!
Dave E
Gwynedd. N Wales.
X-type 2.5 Estate
XK8 Coupe
XJ 4.2 S1
Daimler 2.5 V8
Gwynedd. N Wales.
X-type 2.5 Estate
XK8 Coupe
XJ 4.2 S1
Daimler 2.5 V8
Thank you, Dave.I hope you get it sorted, I do like a 3.2S!
This is my second Moroccan Red 3.2S. First one I sold but shouldn't have. I'm trying not to make the same mistake again.
Aidan
Hi Aidan, sometimes we need to go back to basics to fault find, even on a relatively modern car. Prerequisites to fire up an engine are air, fuel and a spark. If you can confirm that all 3 elements are present by simple tests, then it would be time to go looking into the electronic trickery that might be causing an issue.
Before going there though, I would agree with Dave that a fuel line / system blockage could be a problem - old, stale fuel is a menace, so when going through the basic fault finding, ensure you have fresh fuel at the rail.
Jim Mann
Jim Mann
Jim Mann
Banchory
Banchory
Thanks for the tip, Jim.Hi Aidan, sometimes we need to go back to basics to fault find, even on a relatively modern car. Prerequisites to fire up an engine are air, fuel and a spark. If you can confirm that all 3 elements are present by simple tests, then it would be time to go looking into the electronic trickery that might be causing an issue.
Jim Mann
I hope to get time to poke around this weekend.
Aidan
Why not try some "easystart" blown into the intake pipe. If it fires you are on to a winning clue!
Yes, this is my plan for tomorrow morning.Why not try some "easystart" blown into the intake pipe. If it fires you are on to a winning clue!
I'll report back.
Thanks, Alec.
Aidan
the first and easiest check with these , is, when the car cranks does the rev counter needle "bounce". If it does you have a good CPS and need to move on, if it stays statix, the CPS has failed, swap and you should be ok
do the usual checks as others have suggested first, check for spark, easy , pull a plug and check, fuel, easy, break the line at the regulator, a very quick turn of the key, as the pump pumps against the regulator, and you should have fuel, BE CAREFUL, there is a fire risk here so be prepared
other less known faults on these cars, are as follows, The left hand fuse box corrodes internally, they look good, but are in fact goosed. A good trick is to use a right hand fuse box, different part numbers, but identical parts!!. The fuel pump loom connectors burn out, used to get lots of these, remove spare wheel, boot backboard, this will reveal the tank , you will see a large black connector with red/black wires iirc, split this connector and check for burns to the terminals, if burnt cut and replace with good wiring , I use to do so many I get a link loom in stock all the time
